As you can see from the pic, lengthy scripts are visibly cut in the controller section and the text box appears blank, the scripts work, operationally it isn't a problem but it's still a bug, just not an important one.
geposted Sat 18 Apr 15 @ 6:53 am
Did you try to resize the window after extendig the column for the script?
Maybe its just a redraw issue.
geposted Mon 20 Apr 15 @ 3:22 am
When I resize the window the column width resets.
geposted Mon 20 Apr 15 @ 3:33 am
