Forum: Old versions
Topic: VDJ 8 Process
Ok Problem I'm Having Is That Virtual DJ 8 Stays Open In The Processes And I Cant Open It Again Till i Log Off Or Restart My Computer Not Only That When Exit The Program It Dose Not Exit At All I Have To Click End Process In Processes For The Program To Exit But The VDJ Process Stays On There Any Help Please?
geposted Mon 20 Apr 15 @ 1:51 pm
What sound interface (soundcard) do you use ?
Well I Have The Realtek High Definition Audio And My M-audio Xponent... But The Main One I Use Is My M-audio Xponent Sound Card...
Its a known issue with M-Audio sound cards. Try to unplug the controller prior closing VirtualDJ
Thank You Very Much I see That Your Right The Prob Is My M-audio Xponent Just Turned It Off And Restarted My Computer And Program Had Close With No Problem Now Is There Any Fix That I Can Do To Fix It?
Unfortunatelly no.
For some strange reason M-Audio drivers fail to release the device peacefully.
Therefore the only current solution is to uplug your sound card prior closing VirtualDj
