Forum: Old versions
Topic: Struggling moving a cue with correctly
I've got this that uses a cue as a return playhead when in slip conditions, at quartz lock it's perfect
Pitched the cue lags or leads inverse to the pitch,( I believe)
deck 2 set_cue 17 & set '$2SSW' '`get_time "absolute" & slip on & loop 0.625 & repeat 33ms 33ms & down ? loop 98.5% & set '$2SSW' "`get_var '$2SSW' & param_add 33" & get_var '$2SSW' & param_cast 'ms' & delete_cue 17 & set_cue 17 : delete_cue 17 & loop 0 & slip off
Any help would be great or even a alternate route.
geposted Sat 25 Apr 15 @ 12:13 am
