Forum: Old versions
Topic: Gemini g2v not working properly
So I have been searching for over 30 minutes and have not found anything.
First off I have a g2v made by Gemini.
Came with the vdjle (I also downloaded vdj8)
Did all the instructions on the download for device and mapping.
So when I get going in vdj8 my tempo (pitch) fader is almost all the way up on the software but controller its at 0. When I move it on the controller to make it back to 0 it does nothing. If I move the fader all the way up it will set off cues or samples loops. Even if I use the vdjle version does the same thing. Also just noticed booth control will set off the cues and samples also and make side 1 start playing if I had nothing in the deck it will pick whatever. So that being said idk what I am or not doing wrong?
I have contacted the seller off eBay they have yet to respond that's been over 72hours.
Also contacted Gemini and a guy there just had me to reinstall everything but still did not fix problems.
geposted Sat 25 Apr 15 @ 12:48 pm
I have pics of the problems but don't know how to post on here.
