Last night at a gig I was performing VDJ would crash seemingly randomly. I believe it happened a total of 4 times.
The first time I was attempting to load a song that I had just moved into a monitored folder.
The second time I am unsure what lead to it.
The 3rd and 4th time I was trying to preview a song on my headphones.
I have a DDJ-SX and it seemed that the sound card in the SX would disconnect and I would have to re-apply the audio config. My sidelist would also clear.
I had the following in my crash log.
Crash ID=004a0fd5 (date=1106261901, version=7.0 Pro, build=342, thread=Main, dump=2b581003, excode=c0000005 (0,10))
Crash ID=77078e19 (date=1310151845, version=7.4 Pro, build=453, thread=Main, dump=ff40148b, excode=c0000005 (1,14))
I would very much so appreciate any help that can be given.
geposted Sun 26 Apr 15 @ 1:38 am
Same Build 2206.971 .
For the first time (since the Beta-Start -with live gig´s) I had after four hours the prob that the left player was completly blocked . I could not change the tracks.
I had the feel that the Vdj-ram was not flushed and had a overflow.
After a restart nothing changed (I tried it three times !) So I worked with one player (Strange -:) After 45 minutes the first player recovered alone .At least it lasted not very long. The next song blocked again. I finished my job with cd and 1 player.
There was no crashreport ......Win 7 ultimate x64 . Denon Hc 4500, Asus 2,4 Ghz Dualcore
geposted Sun 26 Apr 15 @ 7:34 am
Just so you know OP those are crash reports for v7 ;)
Unfortunately we have no report for you from v8; if you can replicate whilst connected to the internet it would be helpful.
geposted Sun 26 Apr 15 @ 7:50 am
Thanks for the reply.
Is there no function that the crashreport is stored until it´s again online. If -I was today online with the laptop-maybe it was sended.
geposted Sun 26 Apr 15 @ 10:24 am
I've had two crashes over the weekend as well with this same build. Both instances I had iTunes and Virtual DJ up and running. Songs loaded and ready to play in VDJ after my "background music sets" were finished in itunes - went to use VDJ and it had frozen. Very frustrating!
geposted Sun 26 Apr 15 @ 6:01 pm
