Issue : As a former technique sl1200 user I notice the pitch control in virtual / IDJ3 is way off compared to my
1200s. Basically you move pitch a little bit and the record jumps way too fast.
This is the system im using: Windows Vista Home
Memory 3 gb System 64 bit
Pentium Dual Core Processor t4200 2.00 ghz
Any help would be appreciated.
geposted Sun 26 Apr 15 @ 6:03 am
adjust pitch range to 8% or 10% closest you will get
pretty sure the range on a 1200 was 8%
also keep in mind those pitch fader were probably much larger on the 1200s with made them move in smaller increments
geposted Sun 26 Apr 15 @ 6:14 am
You shoud think about updating your Computer. VISTA is not very stable and has different problems with ASIO, MIDI and HID.
Greets, Heiko
Greets, Heiko
geposted Wed 29 Apr 15 @ 2:20 am
