Forum: Beta Builds Regression Bugs
Topic: BUILD 2218
-effect_select can scroll through effect popup if opened
-sample_color working for remix mode
-internal effects can now also be ordered in sub-folders
-Plugin subfolder with name 'ignore' will be ignored while scrolling with effect_select, or random video transition selection
geposted Sun 26 Apr 15 @ 11:15 am
when you click on the viewfinder is not located...
Before posting here, please ensure that it is a regression bug. Try to install a previous build and see if the issue is gone. If the issue is still present then either it's an older bug and should be reported in the bug report forum, or there's another reason why it's not working for you.
ok , sorry , if I had this problem and in early versions ...
Sound problem, locking in the course of music... :( windows 64bits
I can directly close VDJ with X, there is noch safety question
MAC OSX Mavericks
Is ANY of the decks playing?
Security works only if at least one deck is playing
It will allow closing (even with loadSecurity to On) if the Master Deck is not playing.
What sound setup are you using ? External mixer or Master & Headphones ?
but anyways, i dont think that this has anything to do with the current beta build, not a regression one, so please continue and provide more info to a topic in the Version 8 Bug Report forum, not here (unless you can only reproduce this with the current build and not some previous one).
white flasheos returned again to the skin ...
Little problem with change Transitions with controller. Now i have All´s EFX
where did the export to .txt option go? (playlists / history)
Had this happen previously when I tried to update.
This is the message I keep getting.
Tried to update and now I get a message saying
"App cannot run on your system contact software publisher."
It seems that some of my transitions have stopped working
my tracks are still not appearing in the virtual folders in vdj8 latest build mac version
