-Fix effect_select regression causing effect filters not to work properly
-Fix automatic re-analyze overwriting custom bpm/phase when scan version is updated
-Fix reading certain playlists on mac
-Sort playlists listed in folders alphabetically
-Ensure zeroDb config value does not get invalid
-Improve automatic deck assignment for controllers when some controllers have been assigned manually
-Custom remix points don't get overwritten when re-analyzing
-get_slip_active action added
-Fix login using Google ID broken
geposted Thu 30 Apr 15 @ 9:39 am
What is the back story on that?
geposted Thu 30 Apr 15 @ 9:50 am
I'd like additional info on '-Ensure zeroDb config value does not get invalid'.
Does that mean there's a potential issue using absolute values vs. the dropdown options?
geposted Thu 30 Apr 15 @ 10:58 am
No. But before you could type 0 or -3 (as a value, not choose from the box) and it would become messy (valid values are 0.1 -1.0)
geposted Thu 30 Apr 15 @ 12:41 pm
Have nobody Problems with Pioneer ddj SR or sx?
The mappings are different!
In last beta versions i deaktivated the crossfader, now it is possible to use it.
On sx i think the sound between Two decks are different... I will check it the next days, now i play with it.
Sx- wheel led have Different mapping
Mac OS X
Gain deck 4
Mac OS X
Gain deck 4
geposted Thu 30 Apr 15 @ 5:01 pm
@dcomo I think there'll just be a check is the input is a reasonable/valid value, If no it'll revert to a previous/default.
geposted Thu 30 Apr 15 @ 7:07 pm
Are you sure its the DDJ-SX and not the DDJ-SX2 that you use ??
If its the DDJ-SX2, there is a known issue with the GAIN/TRIM knob (not providing linear values), and we will try to find a workaround very soon.
Nothing is changed on our side regarding any Pioneer DDJ-series mapping files.
geposted Thu 30 Apr 15 @ 8:51 pm
-get_slip_active action added, :-) not a bad idea, any reason "dump" got neglected? Also the marker on the vertical scratch.
geposted Thu 30 Apr 15 @ 9:55 pm
dump and reverse act the same way regardless of the Slip mode though.
geposted Thu 30 Apr 15 @ 11:09 pm
I suppose it isn't a worry, keeping count with dump is easy and it's never for long,
Quiet fix on bpm with pitch <50% too, nice.
geposted Fri 01 May 15 @ 1:28 am
Understood. I always understood that value to be 0.1 through 1.0, so it's clear.
geposted Fri 01 May 15 @ 8:46 am
