- CUAudio catalog fallback to NetSearchAudio automatically
geposted Fri 01 May 15 @ 9:33 am
I''m on the new build (2231), when I search audio in Content Unlimited a list returns of only purple icons. Why am I not getting list of songs with red icon? Thx
geposted Fri 01 May 15 @ 11:30 am
Because the CU audio service has been suspended.
geposted Fri 01 May 15 @ 11:34 am
we're working to get them back as fast as we can
geposted Fri 01 May 15 @ 2:12 pm
i'm still having same problem with every new build ,the tracks in the virtual folders are disappeared when i come to open, i have to go back to previous build 2191to see the tracks ,i have vdj8 mac version,till now no one is answering me
geposted Sat 02 May 15 @ 8:51 am
Hi, i'm also on Mac and can't reproduce the problem you wrote.
Is there a chance you can create a screen record with quicktime and upload it on youtube to share with us?
Start with your working version and then with the actual build.
geposted Sat 02 May 15 @ 10:57 am
i am unable to use netsearch on either ver 7.0 or 8.0? this started last week. i know they are having some issues, but I thought that only affected 4800 songs?
geposted Mon 04 May 15 @ 11:03 am
geposted Mon 04 May 15 @ 3:19 pm
It’s the weirdest thing. I updated to the build 2231 and my version of VDJ8 locked up. Since then, I have not been able to go into Audio settings and click the “Verify” setting button without the program locking up every single time.
As you can see in the attached video, without my Denon controller attached, VDJ8 is informing me that there is no soundcard. I go ahead and open the program and everything works as it should just using the keyboard.
However, if I go into settings—Audio and click on anything then Verify, the program locks up and I have to force close.
Things I’ve tried:
Gone into settings to see removing the MC6000 from the sound card list
Hooked up a different controller to see if that might clear a “Cache” somewhere (MC2000 & Mixtrak Edge)
Tried making the change in audio settings while controller still attached
Changed my skin back to the default skin
Rolled back my build to a previous build
Reinstalled the latest build and downloaded directly from website.
Tried doing a Factory Restore (For some reason, cannot factory Restore. Clicking Factory Restore locks up Proggie too)
None of the above experiments worked.
As long as I don’t try to manually change the audio settings, VDJ works as normal. I did a 3 hour event on Sunday night without a hitch (Backups in tow of course).
When I hooked up the other controllers, I could hook, unhook the controller and just use the keyboard as long as I left the audio setting to Master & Headphones. If I attempted to Click on Speaker only, WHAMO!!! Lockup.
Oye ve!!
Any thoughts. See video below --->
Video: https://www.youtube.com/watch?v=u2YygUTHi6g
Things I’ve tried:
Oye ve!!
geposted Mon 04 May 15 @ 4:02 pm
@ProfLee
you could try and make a backup copy of settings.xml then delete it from vdj folder then start the program maybe the file has been corrupted reinstalling and updating doesn't over write this file.
geposted Mon 04 May 15 @ 4:12 pm
wickedmix wrote :
@ProfLee
K, will try that. Thanks for the input.
geposted Mon 04 May 15 @ 5:46 pm
To Wickedmix-
BINGO!!
That was it. As you suggested, I saved a copy of the settings.xml, restarted VDJ and everything back to normal.
Needed to reconfigure a few settings and and other minor things but I am a happy camper now.
I owe you one...
BINGO!!
I owe you one...
wickedmix wrote :
@ProfLee
geposted Mon 04 May 15 @ 8:54 pm
Do you still have the problematic settings.xml ?
It would be useful for us to find the cause of your problem.
geposted Mon 04 May 15 @ 11:45 pm
See above-
Somehow my settings.xml got corrupted. But it wasn't the build 2231 that corrupted it because I was getting the error message way before this. It's just that after installing the build 2231, I started having a specific problem. Turns out, my settings.xlm was corrupted. Don't know when it started but by deleting it and restarting the program, all is fixed.
geposted Tue 05 May 15 @ 9:42 am
