"Tag m4a and flac"
You don't write or read all tag of tag editor in file .m4a or .flac like:
- remix
- Remixer
- Label
Is it possible to write and read these tag like for mp3 files for m4a and flac files
- remix
- Remixer
- Label
geposted Sun 10 May 15 @ 10:56 am
@Archi95490 i'm afraid this isn't a regression bug or anything new have a look at this -> https://virtualdj.com/homepage/wickedmix/blogs/5246/id3_Tag_Support_in_VDJ8.html
geposted Sun 10 May 15 @ 11:03 am
Hello,
I have the latest build. I am listening to tracks via the pre listen tab with only the internal PC sound card. When I right click and delete a track the next track below is highlighted. I play that track in the pre listen window and the software reboots. I try to play the same track in the pre listen window after the software reboots and nothing happens. I check the sound card settings and internal card isn't selected so I select and still no sound. I reboot the software, select internal sound card and it works again. I've tried this twice with same results.
geposted Sun 10 May 15 @ 8:05 pm
A few people mentioned crashes in the pre-listen area. I would suspect they will be addressed in the next release.
geposted Sun 10 May 15 @ 10:49 pm
Yes, this bug (specifically deleting or moving files that have been played in prelisten and using prelisten again after) will be fixed in the next update.
geposted Sun 10 May 15 @ 11:10 pm
Braenzu wrote :
I think i heard tempo fluctuations with this build in the songs
I have heard this on several occasions. Like the music 'warbles' in pitch, but not tempo. Kinda like the old days of 'wow & flutter'. Yes, I have many VBR files but all new tracks are CBR.
Has anyone else heard this?
This build, no but other builds, yes. Quite odd to hear it.
geposted Mon 11 May 15 @ 12:46 pm
milkdrop to activate and switch effect , produces brake on skin ...
geposted Mon 11 May 15 @ 5:35 pm
that's what I meant, sorry
geposted Wed 13 May 15 @ 10:58 am
Value of "pitchQuality" in VDJ ?
geposted Wed 13 May 15 @ 3:22 pm
2
geposted Wed 13 May 15 @ 3:48 pm
