hello, the pick-up seems really slow, so scratching and cueing choons is really hard, is anyone else having this issue or is it just me? any help would be great.
Once you release the platter you get about a 1- 2 second delay, really wanna get this resolved as my mixing is suffering, and it wasn’t too hot before the upgrade to 8.
geposted Thu 07 May 15 @ 5:42 am
Try turning off the touchwheel backspin setting in options and see if that improves it, but be warned you'll no longer be able to backspin as it will stop once you release the platter.
geposted Thu 07 May 15 @ 7:40 am
cheers for the tip, will give it whirl tonight, worked perfectly fine in VDJ 7 not sure why they changed it
geposted Thu 07 May 15 @ 8:36 am
hello sorry for not giving update sooner, but did a factory reset and now everything seems to be working, platter pick up is a lot better...so thanks a lot for what ever was fixed
geposted Wed 13 May 15 @ 10:03 am
