Another oddity involving slip,
slip_mode off,
Turn a loop on,
turn slip_mode on,
(Point 1 slip_mode doesn't work now)
Turn loop off
Turn loop back on,
(point 2 slip_mode still not working)
It seems if slip mode is turned on during a loop no slip loop action occurs, oddly slip scratch does
slip_mode off,
Turn a loop on,
turn slip_mode on,
Turn loop off
Turn loop back on,
geposted Thu 07 May 15 @ 12:51 pm
Correct, this is intended behavior so that you can do scratches within a looped part without jumping somewhere else when disabling the loop.
geposted Thu 07 May 15 @ 1:13 pm
Thanks for the reply, that makes sense now, I'll switch to global slip.
geposted Thu 07 May 15 @ 1:48 pm
