Topic: Wave form deck B
I established a virtual dj8 on a laptop (HP ProBook 455 G1), and my favorite skin (Pioneer DDJ Skin) wave form is not visible on deck B. Wave seen if you turn the loop on Deck A. At the other skins does not. Thanks ...
geposted Fri 08 May 15 @ 2:53 am
reset the video driver, the problem is solved, thanks ...
I have long wanted to use already, thank you very much;)
I have this same problem using the VMS 4.1 skin. It used to work ok. How do I reset the video driver?
I still have this problem on deck B? Anyone there to help please?
You haven't said what type of computer or OS you're using - but on Windows, check the make /model of the graphics chip/card in your system, then either use Windows itself to update the driver, or go to the website for that particular make/model of graphics and download an update from there.
You may even find it better to go back a step (install an older driver) - again, depending on your system/config.
If the above directions confuse you, try a Google search for how to update your graphics driver.... :-)
