Hello All,
I am new to this forum but been using the great vdj software for some fun dj’n at home. For some reason recently I will up a certain song onto one of the decks and it will only load about half the song instead of the entire songs (just my luck its one of my very favorite songs). For other songs I use it all loads onto it. If anyone can help me out with this issue I would greatly appreciate it!
Thank you so much for the help,
P
Edit: initially as it loads onto the deck it shows the full 6 min length of the song then it cuts to only having 3 min of it on the deck :((
P
geposted Sat 09 May 15 @ 9:38 pm
Which version ? V7 or V8,
What is your maxPreloadLength option set to (I can't remember what it is called in V7)
geposted Sat 09 May 15 @ 9:56 pm
This may be because the file is variable bit rate (VBR) - Please see the following FAQ page:
https://virtualdj.com/wiki/MaxLoad.html
geposted Mon 11 May 15 @ 7:51 am
