Forum: Old versions
Topic: Default Mapping issues for Behringer CMD 4A
Just wondering if anyone else has had issues with the default mapping for the CMD 4. The default did not work correctly when going to vinyl mode for scratching. I worked through that one. The only thing that I have found so far is that I have been unable to get the meters to work on the unit. The mapping seems to be correct and when the unit initializes, I see the deflection of the meters, so I know they're not completely dead. Hoping someone else has seen this. I'm pretty good with mapping, so the frustration level is going up exponentially. Any help is appreciated.
Virtual DJ Pro 8 Infinity
Windows Professional 7
geposted Tue 12 May 15 @ 9:49 am
Do they work with the "factory default" mapping ?
Do you have "Master" and "Headphone" in Audio configuration ?
If for any reason Master is not included in audio config (e.g. for some reason you have External mixer setup with deck 1, deck 2) then a different mapping approach is required.
Controllers will only work for 10 minutes at a start, unless you login with your Pro, Plus or Subscription account (which is not the case with the one you used to post here).
