Forum: Old versions
Topic: usb sund card problem
hello yesterday i bought a usb cheap soundcard.i open my laptop,i open vdj and usb soundcard work great.i could do pfl and and and ,anyway all working fine!! today i do the same but i put the usb soundcard into other usb port.i open vdj and an error show in my screen and in the right corner of my screen writes " Virtual dj - no soundcard" . i re-instal vdj but nothing.i cant do pfl.any ideas with this problem?
geposted Wed 13 May 15 @ 7:40 am
What happens if you put the soundcard back on the original USB port ?
Most likely Windows did not detect the device properly on the new USB port
nothing again! i dont know what to do.i re instal vdj twice .but nothing
you have no idea about my problem?
If I were you I would start by opening Device Manager, connect your soundcard and see if it is detected properly or there seems to be a problem (one or many components with a yellow ! next to them for example).
It is obvious that it it is not properly installed and detected by the computer that you will not be able to use it in VDJ.
