Forum: Beta Builds Regression Bugs
Topic: BUILD 2265
-fix get_beatgrid action to match description
-fix decoding wma files when output samplerate is 192kHz
-fix for numark nv automatic deck selection of displays being wrong
-support for custom mixer order for 4 deck controllers
-new action effect_slider_active
-Fix video drawn not pixel-perfect in some cases with DirectX
-effects_used 'deck' and effects_used 'master' actions
-Fix prelisten crash when using prelisten after deleting or moving a file previously prelistened
-Fix browser_scroll not scrolling from correct location after dragging a song to a different location
-new action get_playlist_time
-Escape key works to cancel security load window
-Fix possible issue reading remix and remixer field from Ogg and Flac tags
-Fix check to ensure VirtualDJ is visible on screen
-Fix performance problem with Reverb and Phaser when track paused
-Fix popup alerts from config window hidden on Mac
-Fix config record file selector hidden on Mac
geposted Thu 14 May 15 @ 4:28 pm
If its present in the public release then its not a regression bug with the current beta and should instead be reported in the bug report forum in future please.
ok posted there. you can remove my posts. Thanks
i see that there is 8 posts in here and i see only 3, Weird...
Above your (our) level SWID, secret staff conversations.
I understand Thanks...
And it shouldn't show as a new post if we can't read it!
New install of VDJ 8 with build 2265 mac version and i got this...
It happened again when i pressed on the config button I think that what i did last time It happened, what is it ?
-when removing a folder from favorite the software crashes
Os x 10.7.5
Mbp 13" i7 2.9ghz 8gb
