Discussion about Shrink Loop
This FX is a shrinking slipped loop,
Dial 1 controls the amount of times it shrinks (turn this dial to 0% at anytime to exit the effect too)
Dial 2 controls how quickly it shrinks.
The stop button (default off) turns auto exit on and off, so the FX closes when the counter reaches the counter max.
The Auto_X button make the GUI appear and disappear, either automatically or as usual manually.
On the wave form (both position and rhythm) a cue appears to show you how close to counter max you are.
Please bear in mind if you have the stop button on and have both the speed and counter very low you may have the FX switch off without any noticeable effect.
This FX will be opened up to plus & LE licences 3 months from today.
Any thought's, faults or problems please post.
A great many thanks to Scot for much guidance and the brave souls who beta'd for me.
geposted Fri 15 May 15 @ 9:02 am
so better
geposted Fri 15 May 15 @ 8:56 pm
Just had a quick mess around and yeah this is pretty cool, not sure when Id use it but Ill figure it out, lol!!
Good job bro and keep em comin!!
geposted Tue 19 May 15 @ 5:30 pm
There is the obvious, edm style build up, but then there's less obvious uses like single shot loops (loop 1.5, sounds great with break beats) or there's the hardstyle triple,
I think I'll change the minimum counter to 1 instead of 0, (and some other ideas)
geposted Tue 19 May 15 @ 10:54 pm
this is great locodog!!
Thanks!
this is something that reminds me the DaftFunk Vst (even if I would prefer DaftFunk if only it would works for me...).
Thanks!
geposted Thu 04 Jun 15 @ 4:02 am
If you want to try something interesting use the standard Brakestart FX (on a 3 to 10 s setting) while using shrink loop, it sounds pretty good.
geposted Thu 04 Jun 15 @ 9:49 am
mmmmh, not bad!
but I think I prefer set the % of the pitch to 100% and then play with it while Shrink Loop is active :)
geposted Thu 04 Jun 15 @ 4:29 pm
I absolutely love this! But, Doesn't seem stable...
NS7II randomly looses connectivity while using it. I have to power down the NS7II all together to get the NS7 working again. A reboot of VirtualDJ is not enough.
geposted Tue 07 Jul 15 @ 2:57 pm
I'm not sue how this plugin could kill HW, maybe it can but I've no idea.
Other news 8 days and this plugin will be opened up for all users.
geposted Thu 06 Aug 15 @ 8:28 pm
As promised now open to all.
geposted Mon 17 Aug 15 @ 10:35 pm
Hi there!
Could someone share an example of mapping for it?
To use it at its best with buttons/fader/knobs of the controller?
Would it be possible to add a "ramp delay" effect to the Shrink Loop?
geposted Tue 29 Oct 19 @ 8:46 am
When I activate it , it makes automatical more than 100 Hotcues...
What is this??
What is this??
geposted Wed 30 Sep 20 @ 11:22 am
It does? oh damn I thought I updated that, it's the autoSortCues option that causes it. I'll get a fix uploaded.
geposted Wed 30 Sep 20 @ 12:09 pm
Ok , have test it.
It works now prima :-)
Thanks
Thanks
geposted Wed 28 Oct 20 @ 10:39 am
@dev staff, thanks for the quick approve.
geposted Wed 28 Oct 20 @ 11:34 am
Is there a possibility of this effect coming to ARM Mac?
geposted Fri 02 Feb 24 @ 10:52 am
this one not likely at all, I haven't even built a x64 windows version.
geposted Fri 02 Feb 24 @ 1:03 pm
