Forum: Old versions
Topic: Casio Trackformer XW-DJ1 mapping
I'm asking for a mapping for the Casio Trackformer XW-DJ1, is there something in the pipeline for this device?
geposted Tue 19 May 15 @ 5:12 am
Sorry i got the wrong Sub Forum, can somone please move this thread to the technical hardware sub?!
Do you have the MIDI In/Out Communication Protocol available (maybe there is one in the Operation Manual ) ?
I can't find anything in the CASIO Support/Download section for this unit, not even a manual.
EDIT. Actually found the manual but no MIDI info/table there. So can't help you much. You could probably try to create something basic with Simple MIDI or a simple definition.
The unit is of course not supported nor any custom definition is uploaded ever by any user.
If you need to give it a try, start from here https://virtualdj.com/wiki/ControllerDefinitionMIDIv8.html and let me know if u need any help.
EDIT2. Ok found the MIDI Table. Can you provide some info ?
Run VirtualDJ 8.
Goto CONFIG->OPTIONS tab, enable the "Advanced Options" and set CreateMidiLog to Yes.
Close VirtualDJ.
Connect only the CASIO (no other USB sound card or controller) and run VirtualDJ again.
Close again (no need to do anything else)
Post there the content of the Log Report.txt file you will find in /VirtualDJ folder.
Thanks for your reply.
i didn't know abaout the log option jet, i'll try this in the next days and provide you the information out of the log file.
WASAPI device without vid/pid: Lautsprecher (BEHRINGER USB WDM AUDIO 2.8.40) : {2}.\\?\media#busb_audioadapter#7&7dbf6ba&1&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
WASAPI device without vid/pid: Eingang (BEHRINGER USB WDM AUDIO 2.8.40) : {2}.\\?\media#busb_audioadapter#7&7dbf6ba&1&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
Audio device found: name="BEHRINGER USB WDM AUDIO 2.8.40"
Audio device found: name="Conexant 20671 SmartAudio HD" vid="0x14F1" pid="0x506E"
Audio device found: input name="BEHRINGER USB WDM AUDIO 2.8.40"
Audio device found: input name="Conexant 20671 SmartAudio HD" vid="0x14F1" pid="0x506E"
Audio device found: asio="ASIO4ALL v2"
Audio device found: asio="BEHRINGER USB AUDIO"
Audio device found: asio="Pioneer CDJ ASIO"
Audio device found: asio="Pioneer DDJ_SX2 ASIO"
Audio device found: asio="XONE:DB4 USB ASIO driver"
Audio device found: asio="XONE:K2 USB ASIO driver"
Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
MIDI Device Identifying: Microsoft GS Wavetable Synth (in:-1 out:0)
[10:08] Midi Out Closed (Microsoft GS Wavetable Synth)
MIDI Device Not Identified: Microsoft GS Wavetable Synth
--- 2015/06/22 - 08:15
[08:15] Midi In Closed (\\?\usb#vid_200c&pid_103d&mi_03#6&20fe2593&1&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\omnitronic_cmx2000_midi)
[08:58] Midi Out Closed (\\?\usb#vid_200c&pid_103d&mi_03#6&20fe2593&1&id01#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\omnitronic_cmx2000_midi)
--- 2015/06/22 - 08:20
Audio device found: name="Casio XW-DJ1" vid="0x190F" pid="0x5633" hardwareID:"{0.0.0.00000000}.{0a473522-ac47-4580-93e3-f978aa5d98e6}"
Audio device found: name="BEHRINGER USB WDM AUDIO 2.8.40" hardwareID:"{0.0.0.00000000}.{188db6ad-8411-4c22-9822-b281e2d171e6}"
Audio device found: name="Conexant 20671 SmartAudio HD" vid="0x14F1" pid="0x506E" hardwareID:"{0.0.0.00000000}.{cc9b6da7-3099-4725-b00e-2f9ed9bbaf56}"
Audio device found: input name="BEHRINGER USB WDM AUDIO 2.8.40" hardwareID:"{0.0.1.00000000}.{8b1f2ed7-aba5-4fd5-9658-abec12ca9583}"
Audio device found: input name="Conexant 20671 SmartAudio HD" vid="0x14F1" pid="0x506E" hardwareID:"{0.0.1.00000000}.{d4a53cda-df1d-4fe5-b5c0-1172617e2f4a}"
Audio device found: asio="ASIO4ALL v2" hardwareID:"232685C6-6548-49D8-846D4141A3EF7560"
Audio device found: asio="BEHRINGER USB AUDIO" hardwareID:"581ABE50-4577-45C8-B41FF202C45D32AE"
Audio device found: asio="Casio ASIO Driver" hardwareID:"6287458B-CD0D-442A-AE961E47611158ED"
Audio device found: asio="CMX-2000 ASIO driver" hardwareID:"5C17B94C-0464-4823-90604295388D11F6"
Audio device found: asio="Pioneer CDJ ASIO" hardwareID:"28032B99-BCB8-4843-B9C6C300BD6F80BA"
Audio device found: asio="Traktor Audio 2 MK2" hardwareID:"AD6BF676-4E04-4BE2-8BAE500554A62A86"
Audio device found: asio="XONE:DB4 USB ASIO driver" hardwareID:"E907BE36-6F3D-4BF2-879C6123C62B804A"
Audio device found: asio="XONE:K2 USB ASIO driver" hardwareID:"5CF06AC8-BD31-43D0-B8BD7919054C224F"
MIDI Device Identifying: \\?\tusbaudio_enum#vid_190f&pid_5633&ks#6&b751958&0&4#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\midi_in_00_00 (in:0 out:1)
(trying to match sysex for \\?\tusbaudio_enum#vid_190f&pid_5633&ks#6&b751958&0&4#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\midi_in_00_00 : found F07E7F06020040026002000000260000F7)
MIDI Device Identified by general midi: \\?\tusbaudio_enum#vid_190f&pid_5633&ks#6&b751958&0&4#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\midi_in_00_00
[08:28] Midi Out Closed (Microsoft GS Wavetable Synth)
[08:20] Midi In Closed (\\?\tusbaudio_enum#vid_190f&pid_5633&ks#6&b751958&0&4#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\midi_in_00_00)
[08:43] Midi Out Closed (\\?\tusbaudio_enum#vid_190f&pid_5633&ks#6&b751958&0&4#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\midi_in_00_00)
Ok will email you some test files within the day
Email sent
Your feedback is appreciated.
hola alguien puede ayudarme, con la configuracion de los hot cue, en la pioneer sx, para que funcione como serato, desde ya muchas gracias .- saludos
Can i get a copy of the midi mappings for the Casio XW-DJ1 please?
Thanks so much for any help. :)
You'll need a licensed/payed for version of VDJ to be able to use it
