Topic: DECK B EFFECT ON.....
I was djing the other night and was using the effects on deck b it would not turn off it was not on and could only be fixed by restarting virtual dj how could I resolve this. Has happened more than once
thanks for your help in advance
geposted Wed 20 May 15 @ 4:22 pm
Which Effect was selected on Deck B ?
It was the flanger effect
What hardware/controller were you using that night ?
Are you using some custom mapping or the default one ?
Was the Flanger Effect selected on deck B and turned ON (red button on the Default skin) ? Maybe enabled in some other Effect slot ?
Can you reproduce that ?
Even when I turned it off was still on
No controller...... default skin
