Forum: Old versions
Topic: Song starts playing faster than usual
Hi all,
I encountered an issue with the latest version of Virtual DJ 7 on an OS X Lion Macbook with a Denon MC-6000 the other night at a gig. Twice while headphone cuing the next track, the next track's waveform would suddenly move faster than normal. The problem is very difficult to explain - I wasn't able to use the sync button or adjust the pitch in a way that would slow the song to sync with the other. This problem occurred while using the jog wheel and pitch bending to beat-match. I had backups so I was able to keep playing while restarting VDJ. Restarting resolved the issue, but it happened twice - just wanted to see if you guys have had any experience with this issue? I haven't been able to replicate the issue since.
geposted Thu 21 May 15 @ 8:36 am
Sorry. Haven't had my morning coffee yet. This should be in the Mac support section.
So it's like the pitch bend command got stuck?
I run into this with keyboard use (I know why too,), I didn't think HW suffered from commands sticking, if it happens again press the pitch bend button (whichever you were using) that's the keyboard fix.
that or perhaps you HW is malfunctioning.
