I'm using the great skin, Swap 4 decks by DjDad and there is a small bug in the text of the harmonic number, see picture
May anyone point out where in the XML file I could change to either make the characters smaller to fit or add space for them.
Thanks in advance!
Thanks in advance!
geposted Fri 22 May 15 @ 2:03 am
Weird, it looks OK here. Is that a Retina Mac ?
Anyways, open the XML, search for "Pcamelot". You will probably find 12 or 16 textzones like this..
<textzone>
<size width="80" height="20"/>
<pos x="+390" y="+64"/>
<text size="17" color="#E1E1E1" weight="bold" align="left" format="%Pkey / %Pcamelot"/>
</textzone>
Change the size of the text to a lower value or try to increase the width.
Since its probably just an issue with some specific values that dont fit you may also edit the format to "%Pkey/%Pcamelot"/> (i deleted 2 x spaces there)
<textzone>
</textzone>
geposted Fri 22 May 15 @ 4:00 am
No it's a PC.
And as always thanks for great support!
geposted Fri 22 May 15 @ 4:20 am
