Forum: Beta Builds Regression Bugs
Topic: BUILD 2282 - Page: 1
-Fix 'effects_used "deck"' action
-Fix for relativetouchslider option on HID sliders
-Fix for rhythm wave sometimes not fully drawn
-Better results for netSearchAudio
geposted Fri 22 May 15 @ 3:18 am
"Fix for rhythm wave sometimes not fully drawn" - does this effect the waveform on the CDJs not always loading fully?
- Fix for rhythm wave sometimes not fully drawn,
Cool, I ran into this a couple of times but couldn't figure how to replicate.
No, but I use a pair of 2000 Nexus and haven't run into the waveform not loading fully. If there's an existing topic we can discuss it there; if not then open one and we can investigate :)
First crash experience after months! Thank god i was not live... Opened VDJ, analysed some files, edited some tags, loaded one song (by double clicking on it) goes to Deck A, set a Hot Cue, double click on another song, started loading on the Deck B and CRASH! VDJ restarts with the tracks already loaded on the decks where they were... I am online you should have the report :D
Also i've noticed that the BPM grid on the tracks after analysing is one beat too early (at least 10 different tracks and BPMs, all MP4s)... That means the first beat is set as the 16th and the second as first. It was really good at previous builds.
We have well received it.
It looks like a crash due to one of the following plugins:
C:\Users\GS60\Documents\VirtualDJ\Plugins\Visualisations\TellyMediaV.dll
C:\Users\GS60\Documents\VirtualDJ\Plugins\Visualisations\milkdrop8.dll
or the internal fx "Pixelate"
note here another problem similar to mine, from BUILD 2206.
vdj8 completely remove my laptop. I work only with vdj7
now that others have the same problem as me.
I know I am not alone in this problem is good that we could document.
I use the 4MX v8 skin. in previous versions i could assign effects to the 6 DJC buttons, but now I can only assign things like loop in, loop out, hot cues etc. Previously I was able to assign either effects or looping and cues. The option is no longer available for effects however
No effect was active at the time, nor any transition made... I have only loaded songs on decks
But it was video files?
yes i've already mentioned that they were MP4 files (video)
Ughhhh what ever you guys did.. un do it.. lol... i ALL OF A SUDDEN LOOSE CONTROL over my MC6000 RIGHT IN THE MIDDLE OF A PACKED DANCE FLOOR... thank God for Auto play and knowing my way around short cut keys and all.. (this is why it's important to know the program well) Please let me know what is going on????
Thanks
Search by year+artist don't work e.g. "2015 Andrea" should give me Andrea Berg Songs released 2015 + all other include year=2015 and artist begin with Andrea.
Seems that VDJ doesn't recognize 2015 as number if year followed with another info in the search.
Edit: Mac build 2282.985
the same problem on Win build 2282.985
also don't work "Andrea 2015" and other
Hi all,
I'm getting some strange noises during the transition in Automix, more noticable as it fades across to deck 1. Maybe you can reproduce it.
I'm on a quad core AMD desktop, Wego, fruit skin, 2 deck mode, remove intro outro, 16 seconds fade time, bpm match smart, crossfader smooth.
audio only, mp3's etc.
edit
I get it on my laptop as well, without any controller.
Seeing similar odd behaviour with the beat grid in this version - similar to issue reported earlier in this thread for this release. My previous perception of the beat grid was that it was pretty rock solid, now seems to be one or two beats early.......
BPM Search has a bug
browse to a song with 128 BPM and try this:
search "`get_browsed_song 'bpm' & param_cast 'integer' & param_add -1`-`get_browsed_song 'bpm' & param_cast 'integer' & param_add +1`"
expected: you should get Songs from 127 to 129 BPM
actual: you get 128 to 129 BPM Songs
Same, when you direct search like 127-129
Just tried, searching 127-129 i see results of 127 bpm as well.
mmh.... will work (only) sometimes correct.
demo pool
correct
missed 96 BPM
missed 127 BPM
54%
