Just bought new rig: Asus rog G751jm with Geforce GTX 860m Graphics card. Fresh installs of everything and all drivers up to date. Current driver of graphics card is 352.86.
Can not get Milkdrop to run. When I activate, some skin elements flicker and some skin colors invert.
How can I problem solve this? Is it a know issue anywhere?
geposted Sun 24 May 15 @ 5:32 pm
geposted Sun 24 May 15 @ 8:27 pm
Yes! Thanks Scott
geposted Sun 24 May 15 @ 11:25 pm
Running the Direct X Run Time Web Installer worked like a charm. Milkdrop is an amazing feature. I tried it out on my windows 7 system that I use to test features before loading it on my main system running Windows 8.1. I was prompted to run the update on the test system, but didn't get the prompt on my primary, but knew ahead of time that I may have to run it there as well. Thanks for a great visual effect.
geposted Wed 27 May 15 @ 9:04 pm
