Updating to b2282 reset my settings.xml.
Anyone else experiencing this?
Never happened before and nothing changed on my system. (Except an update of windows defender database)
geposted Mon 25 May 15 @ 12:19 pm
Best I can tell, my settings are intact. Not sure how you updated, but I download only Public copies now and manually install them. Also running Win 7.
geposted Mon 25 May 15 @ 6:49 pm
3 different machines and 3 different o/s's and no error, if you perform the update seq again (if you can be bothered) does the same problem pop up?
geposted Mon 25 May 15 @ 7:01 pm
Automatically downloaded and approved update without resetting settings.
geposted Mon 25 May 15 @ 7:19 pm
Strange... Actually I always update within VDJ if I get prompted.
As I said, this has never happened before and I can't guess why it suddently happened.
geposted Tue 26 May 15 @ 2:45 am
Deinstalled VDJ
Reinstalled to 2276
Auto-updated to 2282
all settings are fine.
So must have been a hiccup, but I'll keep an eye on this.
Reinstalled to 2276
geposted Tue 26 May 15 @ 2:53 am
My settings were erased many builds ago, but I was just getting started with 8 late last year. So it has happened in the past. I too think it was a hiccup then for me too. Would be nice to track down.
Also, if you have a backup of the settings file, could that be restored?
geposted Tue 26 May 15 @ 8:07 am
Yes
geposted Tue 26 May 15 @ 12:11 pm
As above... but you have to do it manually.
Just replace the existing settings.xml with your backup settings.
geposted Wed 27 May 15 @ 3:49 am
