I installed Virtual DJ 7 pro on a Mac running 10.10.3 OS X Yosemite. But my computer does not recognize DJ Console Hercules RMX. What should I do?
geposted Mon 25 May 15 @ 10:54 pm
Try V8 or at least try V7.4.4
geposted Mon 25 May 15 @ 11:02 pm
First thing to do is to verify that your controller is correctly installed on your computer, as indicated in the following documents:
http://ts.hercules.com/faqs/eng/her_eng_00351.pdf
http://ts.hercules.com/faqs/eng/her_eng_00352.pdf
If everything seems correct there, then it should work properly with VDJ.
https://virtualdj.com/wiki/RMX.html
IF however something seems wrong, please let us know what it is so we can help you consequently.
geposted Tue 26 May 15 @ 8:15 am
I have MAC pro 10.10.3 retina 15 inch mid 2015 and, I ben having problems to install my Hercules Dj console Rmx .
geposted Tue 30 Jun 15 @ 4:47 pm
And could you be more precise about what is not working exactly ?
Did you check the FAQ documents mentioned in my previous post ?
Are you using the latest drivers from the Support Site ?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1
geposted Thu 02 Jul 15 @ 6:28 am
I use denon mc6000!!!!
geposted Thu 02 Jul 15 @ 8:25 am
Hi, I am having the same problem. (OS Yosemite 10.10.4)
I followed the instructions from hercules website. (download the new set of drivers, connect the device and restart). When I connect the controller, the lights start blinking and stay there indefinitely. I open the VDJ7 and the software did not interact.
I thought that updating the firmware is the problem and I found some instructions from hercules. Unfortunately, it does not work. I open the Manual update and when I press the MIC On/Off key before connecting the USB cable, the controller continues blinking.
http://ts.hercules.com/faqs/eng/her_eng_00385.pdf
I check the other references mentioned above and the controller is not listed in any references. I just got a new mac, probably I am missing something but I do not think so.
Your help will be highly appreciated.
geposted Sat 25 Jul 15 @ 4:46 pm
