Hi,
when i play videos with Clipbank/random video (VDJ7) , it get stop after a while sometimes the output screen turn black (as in the VDJ video monitors), and sometimes the video freeze. it occurs in more than one VDJ system. The clipbank is defined at the configuration as the default video effect and the Clipbank random video set as active (green).
geposted Tue 26 May 15 @ 5:07 am
Clipbank Version 1.2
geposted Tue 26 May 15 @ 7:03 am
Not sure what is causing your problem, but to get the output showing again you could try... config > video tab > untick and then re tick the activate box at top left of page when this problem occurs. If that doesn't work also try loading a new music video into an empty deck.
geposted Tue 26 May 15 @ 9:12 am
thanks for the advice :-)
I'm still looking for the cause of the problem or preventing this problem.
geposted Wed 27 May 15 @ 7:44 am
I think it is the plugin at fault, can't disable it either.
geposted Wed 27 May 15 @ 8:45 am
