Topic: VDJ8 Music Bugs
Hello I am having an issue where my VDJ8 randomly slows down songs on both of my decks and randomly shuts off songs in the middle of them on only the left deck. I am using the NS7FX on a MacBook Pro 15-inch, Mid 2012 with a 2.6 GHz Intel Core i7 processor, 8GB of ram, as well as a 1600 MHz DDR3 harddrive. Is there anything I can do to fix these issues?
geposted Mon 01 Jun 15 @ 7:08 am
I'm just bumping you up, so others may see this issue. I don't own this setup, but others do, and maybe they can help you. If you are the only one having this issue, then maybe it's not a bug, but a configuration or hardware issue.
