why won't the effects,auto sweep ,echo doppler,balance,filtersbdj,loopout, they use to load fine then came an update from vdj team for version 8,and now they wont load up any more from the scroll down list,so this herc 4mx skin is useless now, can we please get this to work with the plugin effects from your store, if this can't be done then i will need someone to make a skin that maps to the hercules4mx skin and make sure all functions of the herc 4 mx controller to work...not lets have some stuff work,it needs a full lookover in the aspect of everything to work from the controller...ty
geposted Tue 02 Jun 15 @ 10:55 am
Your issue is not related to the skin at all.
You have downloaded the v8 versions of the addon effects after updating to v8, right? Most v7 effects are not fully compatible with v8.
Download > Addons > For VirtualDJ 8
On another note I would recommend you always use a skin designed for v8, as you will find that some things on the skin don't work as they are supposed to, because those things are now different in v8. There is a v8 4Mx skin here:
http://www.virtualdj.com/plugins/index.html?addonid=80162
If you are using the v8 effects, and the v8 skin, then please describe your problem in a little more detail with steps to replicate and error messages or obstructions you receive, otherwise it will be extremely difficult to help you.
geposted Tue 02 Jun 15 @ 12:35 pm
i'm using vdj 8 do not have 7 anymore and i have dled the effect addons from the vdj8 add on section i have them in their own folder and i have opened and installed from the vdj 8 effects folder i made for them.... now i will show u a photo of this issue im seeing in my drop down section of the 6 button effects area http://prntscr.com/7ccbnf... http://prntscr.com/7cccfz ... see they are not their and they used to be their with this version what has changed to make them not be their??? no auto sweep,etc...
geposted Tue 02 Jun 15 @ 1:26 pm
that first link was a pic showing i was on hercules 4mx skin for vdj 8,no biggie its not working the period.....got in the way and broke the link sorry,lol
geposted Tue 02 Jun 15 @ 1:42 pm
Ah OK, you're talking about them not showing up on the DJC buttons, rather than not on the effect list which is what I thought you meant.
This has been fixed for the next updated build.
geposted Tue 02 Jun 15 @ 2:35 pm
yah the auto sweep etc effects won't show in the drop down list which means i can't set those effects to my mixer console,they were working fine 4 days ago and now they won't show in the drop down list so i can use my buttons on my console again..,lol...ok glad to hear that ...ty much
geposted Tue 02 Jun 15 @ 2:49 pm
