Forum: Old versions
Topic: VDJ8 & Denon MC6000mk2 script command "shift"...
Hi all, I'm pretty newbie with programming buttons but I try to learn it even it feels complex, been reading and trying for hours...
So this is what I try to do now... There is a Beat button on the MC6000mk2, which I programmed like this: "FX1_BEATS" - "deck 1 key_move"
to get a function of moving the key... Same with FX2_BEATS, to the 2. deck ... So my question is, how can I set up so I can also change the key
on the 3. and 4th deck while holding the shift-button? I understand that I have to use "var '$shift' or something, but I don't seem to get it right...
Any kind souls out there that can help with a command-line?
geposted Tue 02 Jun 15 @ 2:04 pm
var '$shift' ? deck 3 key_move : deck 1 key_move
Explained; is the variable called '$shift' pressed ? Yes it is pressed, do stuff, : No it isn't pressed, do original stuff
(side note $ means it is global, covers all decks)
Yes that's exactly how I thought it should be, but it only works on deck 3 with that command-line... regardsless if i press shift...
Show me your mapping for your shift button.
Ok your HW has assigns for FX, that might be taking over,
why not try just simple
"key_move"
and work the assign buttons?
Hmm, strange... worked perfectly after a restart of virtual dj. thank you :)
SHIFT assignment -
set '$shift' 1 while_pressed & set 'shift' 1 while_pressed
Hmm, and I found out it was much easier to assign without shift, just use left and right instead of deck number, and use the deck switch button. Using this also on filter knobs.
Wow, nostalgic thread hehe... Have learned so much about the software and hardware since then... Can't believe I asked for this hehe...
Just want to share a little thing I am experimenting with these days about key-changing. I am using a 4-channel mixer and have mapped key_smooth to the front knobs, one for each channel. When I load and clone one song (or mix, easier to learn this with more time) to all channels, at least 3 of them, and have one channel for each of the 3 equalizers and play carefully with for example the channel that is for bass, changing the key smooth up and down following the beat. Or up before a break in the song, and back to normal just before the break is finished. Also playing with effects on each channel. This is awesome, making remixes is pretty interesting with this method. :)
