I have a good idea.
It would be good if you could integrate this function in the normal skin.
Or better yet in the effect of GUI.
You can control them just fine with a mouse pad.
Greatings Dani
Greatings Dani
geposted Sun 07 Jun 15 @ 5:14 am
It can already be implemented into the normal skin.
In fact it believe it is on the touch screen variation of the default skin.
geposted Sun 07 Jun 15 @ 7:13 am
Yes right , that on the Tablet Skin.
And it would be wonderful if you could use this also in the normal Skin.
geposted Sun 07 Jun 15 @ 8:07 am
An example.
So it would look like then.
geposted Fri 19 Jun 15 @ 11:30 am
You don't need two posts running on this, so I'll lock this one as you're posting the same suggestions in the effects thread too.
geposted Fri 19 Jun 15 @ 12:04 pm
