I just replaced my hard drive, and am now reinstalling all my software including VDJ 8. When I downloaded and installed it, everything went as before. However, when I go to run the program, I get no response. I have double clicked the icon, right clicked and selected run as well as run as admin, gone through the compatibility troubleshooting, all to no avail.
It worked fine before I changed the hard drive.
Help!
Help!
geposted Sun 07 Jun 15 @ 9:57 pm
Get windows updated and drivers updated then approach VDJ, works fine with win 7
geposted Sun 07 Jun 15 @ 10:31 pm
when i am open this vdj8 this is not open and see a message like that direct x failed initialize
geposted Wed 09 Mar 16 @ 4:28 am
please check Videocard driver and make sure there are no generic drivers used.
Please install the latest directX9 packages:
DirectX 9C Runtime:
https://www.microsoft.com/en-US/download/details.aspx?id=34429
Microsoft VC++ 2008 Runtime Libraries:
https://www.microsoft.com/en-US/download/details.aspx?id=29
DirectX 9C Runtime:
geposted Wed 09 Mar 16 @ 6:51 am
DirectX update will probably not help you. Please update (or re-install) drivers for your graphics card.
geposted Fri 11 Mar 16 @ 12:34 am
I recently uploaded virtual dj pro 8 onto my pc ( windows 7 o.s) but when I try to run it switches off the computer . what is the problem
geposted Sat 04 Nov 17 @ 7:14 am
Impossible to say based on the information, but often it's driver issues that can bring a PC down like that
geposted Sat 04 Nov 17 @ 7:26 am
it plays for just a few minutes but then the system freezes and shuts down
geposted Sat 04 Nov 17 @ 7:37 am
Best guess is heat without other information. Laptops are designed to shut down when they get too hot. Supply your hardware specs.
geposted Wed 15 Nov 17 @ 8:33 am
