Forum: Old versions
Topic: ns7 on the way
Ns7 fx on the way should be here by the weekend and would love to use it.But should I uninstall my Hercules drivers first and is the ns7 ready to go out of the box.also still using version 7 just curious if it runs smooth
here are my specs windows 7 64 bit 4 gig ram 2.40 ghz and it is a dedicated rig I dont use it for anything eles.
geposted Tue 09 Jun 15 @ 5:52 pm
Out of the box, good to go
other drivers, shouldn't be a problem but that can depend if they were wrote in a half arsed way.
*edit since you have both, why not use both? (completely remap the Herc)*
Dog if you could explain how to do that I will pay you five canadian dollars........haha
Just plug both in and you could run 4 decks, with 2 controllers I'd imagine there'll be loads of interesting things that could be done.
Keep the Herc drivers so you can still use it as a back up, but not together, thats absurd. Install the Numark drivers when you get the NS7 and you will know quickly if your machine is not capable.
Any questions just ask, I've been using the NS7FX for 5 years.
Thanks for the advice will give that a try just waiting for ups guy to show up
