Topic: Virtual DJ Crashes on Macbook Air
I have been using a dell and Lenovo Laptop in the past to run Virtual DJ 8, with no problems. I have recently purchased a macbook air, the newest model, and when I run Virtual DJ, it freezes/crashes as I use content unlimited. Is anyone else having this problem? If so, what is the fix if you've found one......
Thanks
AS an update to my current problem, Virtual DJ runs great when using HD, but after the first song in content unlimited, it freezes. Music will still play, but the screen freezes and I have to force quit the program and restart........Please Help
geposted Thu 11 Jun 15 @ 11:20 pm
I have the same problem!
Please be so kind and try the following for a test.
1) Copy the Cache folder onto a USB stick.
2) Delete the Cache folder on computer side.
Username/Documents/VirtualDJ
You will need to download first some new files by using the CU service.
Does it still crash or did this solve the issue?
If yes, guess it would be best to delete the Backup Cache folder and download again the wanted/needed tracks.
I have exactly the same problem.. Also using OS X (Macbook Pro)
