-New core catalog for ContentUnlimited Audio
-param_1_x action added
-browser_remove action added
-Fix for cdg widescreen playback
-improved using 2 timecodes with 4 decks
-automix skip/mix_now length can be customized (automixSkipLength option)
-BPM editor can be closed using escape key
-exclude playlists from recursion in system folders
-some fixes to automatic deck assignment for controllers
-Fix reset sort order also hiding virtual folders
-Effect ini file is stored for plugin instance that was last modified
-Fix options window at 250% dpi
-Slideshow sorted by filename
-Cover engine speed-up when loading from cache
-Fix possible plugin engine crash on close
-Rewire not re-initialized on each scan to prevent audio dropouts
geposted Fri 12 Jun 15 @ 3:53 pm
Already reported
geposted Fri 12 Jun 15 @ 4:27 pm
sorry guys. Change log is visible now.
geposted Fri 12 Jun 15 @ 4:40 pm
but not custom button, nor poi, editors, Alt+F4 is ok but Esc is better.
*edit* some nice niggle fixing in this build, kudos.
geposted Fri 12 Jun 15 @ 5:09 pm
Since you need keyboard or mouse anyway to do anything useful in the editors I don't think an action to close them is that useful.
geposted Fri 12 Jun 15 @ 5:16 pm
I was thinking symetry, given how open-ended script is, accidentally hitting a (even HW) combo that brings up said editors, Esc is easy to find, Alt+F4 less so.
geposted Fri 12 Jun 15 @ 5:45 pm
Hello , I wonder if this is a bug regreción ...
geposted Fri 12 Jun 15 @ 7:14 pm
@djniconeuquen that isn't showing up here (I'm not having that problem), although it is an odd one but I don't have the Spanish translation to check.
geposted Fri 12 Jun 15 @ 11:16 pm
Regression bug I believe, BPM editor not accepting number, delete key or backspace input. (this time it's not +240 bpm speedcore)
Database isn't set to read only in options. If it's just me let me know and I'll look deeper in to how I broke it.
*edit* Further, can cut & paste (bpm editor number box) from right click but not with Ctrl+C|V
geposted Sat 13 Jun 15 @ 7:52 am
having same issue can't type in the bpm box or paste with ctrl + V this is a biggie.
went back to 2305 and its works again
geposted Sat 13 Jun 15 @ 9:12 am
Checked B & C machines it's this build.
geposted Sat 13 Jun 15 @ 9:50 am
Confirmed and fixed for next build.
geposted Sat 13 Jun 15 @ 3:25 pm
Can you please explain this more, because I have some strange things with 2 x timecode & 2 x cdj. It could be a wrong setting, but there is something wrong in my settings.
geposted Sat 13 Jun 15 @ 4:55 pm
Used this build at my gig tonight. No problems.
geposted Sat 13 Jun 15 @ 6:09 pm
This version produces sounds of frying, the touch buttons and faders move in pioneer aero ...
geposted Sun 14 Jun 15 @ 7:05 am
Confirmed fix For the Options displaying on Ultra HiRes displays.
geposted Sun 14 Jun 15 @ 9:07 pm
And it was a wrong setting, my mistake. Used it last night and everything was ok on a mac with Yosemite 10.10.4
geposted Mon 15 Jun 15 @ 1:22 am
Hello friends!
There is one new issue that wasn't present in early versions. Now there is video cuts and interface cuts prelistening, loading, file brosing network files located on a NAS server.
After correcting the sound cuts when you played video/audio files located on network drives and using automix now I think the video output must be protected.
I think you have improved the song cuts in network drive touching some priority and adding a new process surpervising continuously that the file is present... isn't it?.
But I think this new process is eating too much resources and the video output and interface freezes continously if the interface is touched. When I browse files, load a song, prelisten, always I can see anoying video cuts in the output screen, and interface cuts that there weren't before. I think now the response of the software is slower too. I have tested to activate/deactivate jumbo frames with no differences.
The interface is not for me a big problem but in the video ouput yes because I use it to play karaoke files and play videos and this cuts could be very anoying to my customers.
Best Regards
Manuel
Best Regards
Manuel
geposted Mon 15 Jun 15 @ 4:03 pm
at last !!
2 out of my 3 nags are gone !
now if you would only fix the fx a little bit ( especially the flanged lop out).it does not work as expected
than i would be a happy camper all the way !
geposted Tue 16 Jun 15 @ 7:10 pm
Flanged loop out is not an Atomix effect. The author would need to fix it.
geposted Wed 17 Jun 15 @ 3:08 am
