Is it possible to transfer or import the tracklist file/information from VDJ7 to VDJ8?
geposted Sat 13 Jun 15 @ 1:08 pm
It should automatically do it when you run it for the first time.
geposted Sat 13 Jun 15 @ 2:14 pm
if your tracks are on an external drive make sure its connected
geposted Sat 13 Jun 15 @ 3:43 pm
I think I'm going to test (a bit sozzled now so manyana) but shouldn't V8, if no V8 DB is present but a V6 DB is, then it should work it's magic regardless of first boot , (maybe it does, I suppose I'll find out later)
geposted Sat 13 Jun 15 @ 4:59 pm
If there is no V8 database and folders (in the case of external drives) then it will create one from the old database.
geposted Sat 13 Jun 15 @ 5:43 pm
