Last night lost the sound setting on VMS2 with VDJ8.
Now I can't get the proper settings.
When I go to audio settings and click VMS2, it shows like this pic.
I cannot get just ASIO. If I try to use as it shows, I get no sound.
geposted Sun 14 Jun 15 @ 1:02 pm
Check if the ASIO driver is installed properly. You need to install it manually.
Then select HEADPHONE/MASTER on the left side then VMS in the middle. Normaly it should use the ASIO driver by default if you installed it.
Greets, Heiko
Greets, Heiko
geposted Sun 14 Jun 15 @ 1:46 pm
The audio setup is correct. It should be an External mixer one (Deck 1, Deck 2)
Re-install the ADJ ASIO drivers and always plug the VMS2 to the same USB port and you should be OK
geposted Sun 14 Jun 15 @ 2:05 pm
Thanks guys.
Reinstalling ASIO drivers worked.
I always plug into same USB port for both external drive and VMS2.
I have been having issues with the license, whereby I can only use VMS2 for 10 min. But that is another issue which has been addressed.
When it happened again the other night it must have somehow damaged the drivers.
Never gave that a thought.
Again thanks
Again thanks
geposted Mon 15 Jun 15 @ 7:42 am
Sometimes drivers can conflict each other (use common files etc), so probably you have installed something in the meantime that messed things up.
Anyways, glad you sorted this out. You know what to do next time now ;)
geposted Mon 15 Jun 15 @ 3:07 pm
