I seem to have lost the ability to lock the playing deck so therefore I can load a song on a 'live' deck. I know how to do it but the function just doesn't work. Any ideas ??
No mapping done, just plug and play with a Denon MC6000Mk1
geposted Mon 15 Jun 15 @ 3:57 am
Setting "LoadSecurity" from Settings->OPTIONS tab ?
geposted Mon 15 Jun 15 @ 3:59 am
Tried that. Set to on/off/silent and obviously off wouldn't make it happen but the other two don't work for me either.
geposted Mon 15 Jun 15 @ 5:33 am
Load protection required that you play a deck on the master. If you just preview ist the you still can load a new track as i remember. (Means the deck volume fader has to be up)
Greets, Heiko
Greets, Heiko
geposted Mon 15 Jun 15 @ 6:16 am
