Does anyone know of a dump effect (used to censor explicit lyrics) available in the download center? Looking for something that can mask a lyric vs. a tone that is an obvious censor. Thanks in advance for your feedback.
geposted Tue 16 Jun 15 @ 7:46 am
dunno if this exactly what you need but I looked it up for ya
http://www.virtualdj.com/plugins/index.html?category=samples&search=censored
geposted Tue 16 Jun 15 @ 10:06 am
You can just use the built in command: dump
For example on a custom button you could put: dump while_pressed
geposted Tue 16 Jun 15 @ 10:52 am
Yep there's the in built command for OTF, there's also the track cleaner (a bit of a pain) if you want to prep. but for easier prep I would use the forward reverse plugin and the POI editor, as it's easier to review.
http://www.virtualdj.com/addons/2182/Forward_Reverse.html
geposted Tue 16 Jun 15 @ 11:32 am
