Forum: Old versions
Topic: No Compatible Music Folder
On the PC version in my browser I have a folder I have come to depend on a lot, the Compatible Music Folder. On my MacBook Pro, it is not there. There isn't even an option for it in the browser options.
Any help on getting this feature back?
geposted Thu 18 Jun 15 @ 3:07 pm
It's just a filter folder. You can create it yourself.
geposted Fri 19 Jun 15 @ 2:23 pm
Thank you. Problem solved. Cut copied and pasted from the manual. Now I just need to learn the code for the future. Thanks again.
geposted Sat 20 Jun 15 @ 10:08 am
