Forum: Old versions
Topic: VDJ 7 not saving mappings or clipbank clips
Switched skins and suddenly VDJ is not saving the adjustments to mapping of Numark IDJ3 AND is also not saving the clips I load into clipbank. In other words, every time I restart, I have to re-map my controller and re-load all the clips I have. Is there a setting I am missing?
geposted Fri 19 Jun 15 @ 9:28 am
Maybe because its not possible to change Skins and use Plugins in a LE version?
HA...never mind...I figured it out....if you do not run VDJ as administrator, it will not save your settings. Weird. I thought that kind of junk only happened with Windows Vista.
