where is "Skin Companion" plugin ?
geposted Sat 20 Jun 15 @ 1:47 pm
Skin_Companion.html" target="_blank">Download HERE!
geposted Sat 20 Jun 15 @ 3:26 pm
madlenm wrote :
http://www.virtualdj.com/addons/15782/Skin_Companion.htmlSkin_Companion.html" target="_blank">Download HERE!
geposted Sun 21 Jun 15 @ 12:07 am
works here maybe try a different web browser?
geposted Sun 21 Jun 15 @ 5:55 am
Yes, now I see .dll inside effect folder but prev and nextcue are not showing values....maybe versions incompatibility.
Windows 7 home, VDJ7 pro, another .dll missing etc.
geposted Sun 21 Jun 15 @ 5:13 pm
You need to instal VC 2010 Redistributable from Microsoft.
geposted Mon 22 Jun 15 @ 4:55 am
O.K.
You have written this at Watch dog plugin. Did not help at all... Package 68 or 86 ? Any further ideas ?
Is my controller necessary ? I use VDJ 7.4.1. Pro b482. SC is for 7.3 version which is not available for me now.
Thanx with love to VDJ7
geposted Mon 22 Jun 15 @ 8:38 pm
You need the x86 package
Also you need to edit the options of the plug-in and ENABLE it
geposted Tue 23 Jun 15 @ 4:15 am
All other plugins have activate button except Skin companion. I do not know how to edit or enable .dll file
I also installed msvcp because a warning notice. X86 installed too.....long long neverending story.
geposted Tue 23 Jun 15 @ 11:10 am
Watchdog working - active button and others features visible
Skin companion - active button and others features missing, only empty grey
I would like to make it work, or scrip to see %Bnextcue for VDJ7, please.
geposted Wed 24 Jun 15 @ 7:46 pm
If your plugin has no controls then you are missing the correct runtime library for it.
https://www.microsoft.com/en-gb/download/details.aspx?id=30679 (you only need the x86 version).
Verify that you have msvcr110.dll and msvcp110.dll in C:\Windows\SysWOW64 (or c:\windows\system32 if you only have 32-bit windows).
If you have installed the above runtime and are on 64-bit windows, look for msvcr110.dll and msvcp110.dll in C:\Windows\SysWOW64. If they are not there then something has misinstalled your runtime libraries in the past. You could then look in c:\windows\system32 and try copying them from there into SysWow64 as somehow some people have managed to have them installed in the wrong folders in the past.
We won't be adding new features to VDJ7 though I'm afraid; features requests are for v8 as that is the current version.
geposted Mon 29 Jun 15 @ 5:27 pm
Hello, SBDJ
I have checked everything is OK and on the right place.
I can activate WATCHDOG, your battery status but I cannot activate SKINCOMPANION. There is no corresponding button and or /info.
Is there any difference between Watchdog and SkinCompanion during installation or any other necessary .dll files ?
(Windows 7 home , SP 1, 64bit, VDJ 7.4.6 pro b506). I have already reinstalled Visual C++.
geposted Thu 23 Jul 15 @ 12:42 am
Your best bet is the author of the addon, phantomdeejay.
geposted Thu 23 Jul 15 @ 5:09 am
