On occasion I need to slow a track down as its to fast to dance to. When I slow it down and I'm using automix, the default setting is to mix the next track in and for some strange reason the default is to slow the next and every proceeding track thereafter down.
I have now spent around 4 hrs trying to stop this as I need it to play the next track at a std speed, could anyone please advise how I do this.
geposted Sun 21 Jun 15 @ 12:37 pm
I believe it will be your settings for ResetPitchonLoad under Config - if set to Yes, the Pitch will reset to 0 when next song is loaded.
geposted Mon 22 Jun 15 @ 4:49 am
