How do I setup VDJ 8 to randomly choose video transitions from a certain transition folder Ive set up??
geposted Tue 23 Jun 15 @ 10:38 pm
You can create a folder called 'Ignore' and move the transitions you don't want to be used for random selection into that.
geposted Wed 24 Jun 15 @ 4:01 am
So there's no way to use the ones I have in a folder??
Does your Random video transition plugin work with 8??
geposted Wed 24 Jun 15 @ 11:43 am
There is no way to specify a folder, no.
I haven't done any testing with v7 selectRVT in v8; I did create a v8 version but with the same functionality built in there is no reason to release it.
geposted Wed 24 Jun 15 @ 1:48 pm
Hmm I'll have to do some reading of the manual tonight then because I've put everything except the transitions I want to use into a folder and when I start VDJ I get an error saying there is no transitions and then when it does open everything I don't want to use is there again.......
Maybe you could release your version but add the folder functionality to it since we have no way of choosing a group with the stock version 😏
geposted Wed 24 Jun 15 @ 2:16 pm
