Discussion about Virtually Pioneer
geposted Wed 24 Jun 15 @ 6:22 pm
Rob is there a 4 decks in the works for the future i love your skin looks or possible one with a small window for songs list without having to choose between browser or decks view..
Steve
Steve
geposted Thu 25 Jun 15 @ 11:19 pm
Thank you Steve! I want to do a 4 deck version, but it may take some time as I'm very busy and not sure how to implement it properly. I hear you about the song window... as far as I know I can only use a single browser. I am going to implement a resizable/draggable browser window so you can position it wherever.. :-)
BTW more info here: http://www.virtualdj.com/forums/201315/VirtualDJ_Skins/_NEW___Virtually_Pioneer__(Pioneer___XDJ-RX_skin)_.html
geposted Fri 26 Jun 15 @ 5:40 am
browser window. (1920x1080) to big !!! do you have smaller????
geposted Thu 09 Jul 15 @ 3:33 pm
The browser window is resizeable, just drag the black edges...
geposted Thu 09 Jul 15 @ 6:12 pm
You know what ... Thanks a loy for your work :)- really enjoying your skin ! good work buddy ! keep going on
Dj ( ,)u@rTZ
Dj ( ,)u@rTZ
geposted Tue 14 Jul 15 @ 7:04 pm
My pleasure, glad you like it.. more improvements on the way.... stay tuned :-)
geposted Wed 15 Jul 15 @ 10:20 am
hi rob? virtually pioneer plays very good...
geposted Thu 23 Jul 15 @ 10:16 pm
Yeah just wanted to say thanks for the work! I wanted the RX to get used to the rekordbox feature but also wanted to keep vdj for the content unlimited library I have. much appreciated
geposted Sun 26 Jul 15 @ 11:12 am
i don't own an XDJ-RX as yet, rather the DDJ-SR, but seeing as I still use CDJ1000mk3's I am looking at a 4 channel version of this coming out, hopefully with DVS for timecode for the Mk3's!.. holding fire on any new purchases right now, as I want to see what Pioneer does with Rekordbox..
on a side note - I saw this on ellaskins youtube page (jonathan lewis) a few weeks back.. took me a while to find it as the skin isn't called " XDJ-RX " rather virtually pioneer ;) . great work though Rob, and keep it up!
geposted Wed 19 Aug 15 @ 2:48 pm
Hey there... how to apply this add on?
geposted Thu 10 Sep 15 @ 2:43 pm
Oh i got it
geposted Thu 10 Sep 15 @ 2:44 pm
Do I need to download any other drivers/settings to go with this skin for my Pioneer DDJ-RX for VDJ8?
geposted Mon 21 Sep 15 @ 5:54 pm
hi I really like you skin you have created but my problem is if I download it the skin does want to work on my pc please help
geposted Fri 30 Oct 15 @ 7:35 am
This was is great I'm looking forward for more free things from you bud!
geposted Sat 07 Nov 15 @ 2:15 am
how to install this pionner
geposted Sat 05 Dec 15 @ 6:28 am
hi dose the virtual dj 8 work with the xdj rx anyone
geposted Thu 10 Dec 15 @ 2:22 pm
is this compatible to Pioneer XDJ-R1? thanks in advance
geposted Wed 17 Feb 16 @ 6:00 pm
Bonjour à tous.
Souhaite acheter virtual DJ 8 pour piloter un pioneer XDJ-RX FirmWare 2.10 en utilisant la skin XDJ-RX RobGmixes (ou DJ Zaik Flow)
Quelle version VDJ Pro je dois acheter ? Est ce que le mapping est fourni avec la XDJ-RX RobGmixes (ou DJ Zaik Flow).
J'ai lu que les LEDS sur le contrôleur ne peuvent pas se piloter.
J'ai commencé un mapping sur VDJ8 DEMO le voici si quelqu’un peut me le corriger ou le compléter ou me donner un exemple pour les LEDS.
Google traduction:
Hello everyone.
Wants to buy virtual DJ 8 to drive a pioneer XDJ -RX 2.10 FirmWare using skin -RX XDJ RobGmixes (or DJ Zaik Flow)
Which version VDJ Pro I have to buy ? Is the mapping is provided with the RX - XDJ RobGmixes (or DJ Zaik Flow).
I read that the LEDs on the controller can not control .
I started a mapping VDJ8 on the DEMO here if someone can correct me or complete them or give me an example for LEDs .
XDJ Custom mapping:
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="SIMPLE_MIDI_2276_420" version="800" date="2016-05-07">
<map value="ONINIT" action="deck 1 vinyl_mode 1 & deck 2 vinyl_mode 1 & deck 3 vinyl_mode 1 & deck 4 vinyl_mode 1" />
<map value="0-BUTTON51" action="browser_enter" />
<map value="0-ENCODER79" action="browser_scroll" />
<map value="0-BUTTON0" action="play_pause" />
<map value="1-BUTTON0" action="play_pause" />
<map value="0-BUTTON1" action="cue_button " />
<map value="1-BUTTON1" action="cue_button" />
<map value="0-SLIDER29" action="pitch" />
<map value="1-SLIDER29" action="pitch" />
<map value="0-BUTTON31" action="sync" />
<map value="1-BUTTON31" action="sync" />
<map value="0-BUTTON30" action="select left" />
<map value="1-BUTTON30" action="select left" />
<map value="0-BUTTON81" action="deck active select" />
<map value="1-BUTTON24" action="hot_cue 1" />
<map value="1-BUTTON25" action="hot_cue 2" />
<map value="1-BUTTON26" action="hot_cue 3" />
<map value="1-BUTTON27" action="hot_cue 4" />
<map value="0-BUTTON24" action="hot_cue 1" />
<map value="0-BUTTON25" action="hot_cue 2" />
<map value="0-BUTTON26" action="hot_cue 3" />
<map value="0-BUTTON27" action="hot_cue 4" />
<map value="0-SLIDER48" action="speedwheel" />
<map value="1-SLIDER16" action="jogwheel" />
<map value="1-ENCODER16" action="nothing" />
<map value="0-ENCODER16" action="scratch" />
<map value="0-JOG16" action="jogwheel" />
<map value="0-BUTTON33" action="reverse" />
<map value="1-BUTTON33" action="reverse" />
<map value="0-SLIDER30" action="startupspeed & brakespeed" />
<map value="1-SLIDER30" action="startupspeed & brakespeed" />
<map value="4-SLIDER11" action="crossfader" />
<map value="4-SLIDER95" action="crossfader_curve 'disabled'" />
<map value="4-JOG95" action="crossfader_curve " />
<map value="4-SLIDER18" action="level" />
<map value="4-JOG18" action="get_level_right" />
<map value="4-SLIDER17" action="LEVEL" />
<map value="4-ENCODER11" action="crossfader" />
<map value="4-ENCODER18" action="level" />
<map value="4-ENCODER17" action="level" />
<map value="0-SLIDER16" action="scratch" />
<map value="0-BUTTON32" action="nothing" />
<map value="1-JOG16" action="jogwheel" />
<map value="1-SLIDER48" action="jogwheel" />
<map value="1-JOG48" action="jogwheel" />
<map value="1-BUTTON32" action="nothing" />
<map value="1-ENCODER48" action="nothing" />
<map value="0-BUTTON5" action="track_back" />
<map value="0-BUTTON4" action="track_forward" />
<map value="0-BUTTON3" action="seek -4" />
<map value="0-BUTTON2" action="seek +4" />
<map value="1-BUTTON3" action="seek -4" />
<map value="1-BUTTON2" action="seek +4" />
<map value="4-JOG11" action="nothing" />
<map value="4-JOG17" action="get_level_left" />
<map value="0-BUTTON17" action="master_tempo" />
<map value="1-BUTTON17" action="master_tempo" />
<map value="1-BUTTON6" action="pioneer_loop_in" />
<map value="1-BUTTON7" action="pioneer_loop_out" />
<map value="0-BUTTON6" action="pioneer_loop_in" />
<map value="0-BUTTON7" action="pioneer_loop_out" />
<map value="0-BUTTON8" action="reloop_exit" />
<map value="1-BUTTON8" action="reloop_exit" />
<map value="0-BUTTON44" action="slip_mode" />
<map value="1-BUTTON44" action="slip_mode" />
<map value="4-JOG1" action="nothing" />
<map value="4-SLIDER1" action="gain" />
<map value="4-ENCODER1" action="gain" />
<map value="4-JOG6" action="nothing" />
<map value="4-SLIDER6" action="gain" />
<map value="4-ENCODER6" action="gain" />
<map value="4-JOG2" action="nothing" />
<map value="4-ENCODER2" action="eq_high" />
<map value="4-SLIDER2" action="eq_high" />
<map value="4-JOG3" action="nothing" />
<map value="4-ENCODER3" action="eq_mid" />
<map value="4-SLIDER3" action="eq_mid" />
<map value="4-JOG4" action="nothing" />
<map value="4-SLIDER4" action="eq_low" />
<map value="4-ENCODER4" action="eq_low" />
<map value="4-JOG7" action="nothing" />
<map value="4-SLIDER7" action="eq_high" />
<map value="4-ENCODER7" action="eq_high" />
<map value="4-JOG8" action="nothing" />
<map value="4-SLIDER8" action="eq_mid" />
<map value="4-ENCODER8" action="eq_mid" />
<map value="4-JOG9" action="nothing" />
<map value="4-SLIDER9" action="eq_low" />
<map value="4-ENCODER9" action="eq_low" />
<map value="0-BUTTON35" action="set 'padmode' 1" />
<map value="0-BUTTON34" action="set 'padmode' 0" />
<map value="0-BUTTON85" action="loop 1" />
<map value="0-BUTTON86" action="loop 2" />
<map value="0-BUTTON87" action="loop 4" />
<map value="0-BUTTON88" action="loop 8" />
<map value="0-BUTTON36" action="set 'padmode' 2" />
<map value="0-BUTTON89" action="slicer 1" />
<map value="0-BUTTON90" action="slicer 3" />
<map value="0-BUTTON91" action="slicer 5" />
<map value="0-BUTTON92" action="slicer 7" />
<map value="1-BUTTON34" action="set 'padmode' 0" />
<map value="1-BUTTON35" action="set 'padmode' 1" />
<map value="1-BUTTON85" action="loop 1" />
<map value="1-BUTTON86" action="loop 2" />
<map value="1-BUTTON87" action="loop 4" />
<map value="1-BUTTON88" action="loop 8" />
<map value="1-BUTTON36" action="set 'padmode' 2" />
<map value="1-BUTTON89" action="slicer 1" />
<map value="1-BUTTON90" action="slicer 3" />
<map value="1-BUTTON91" action="slicer 5" />
<map value="1-BUTTON92" action="slicer 7" />
<map value="4-JOG24" action="nothing" />
<map value="4-SLIDER24" action="master_volume" />
<map value="4-ENCODER24" action="master_volume" />
<map value="4-JOG25" action="nothing" />
<map value="4-SLIDER25" action="booth_volume" />
<map value="4-ENCODER25" action="booth_volume" />
<map value="1-BUTTON18" action="vinyl_mode" />
<map value="0-BUTTON18" action="vinyl_mode" />
<map value="4-JOG78" action="nothing" />
<map value="4-SLIDER78" action="crossfader_hamster" />
<map value="4-ENCODER78" action="auto_crossfade" />
<map value="1-BUTTON81" action="deck active select" />
<map value="1-BUTTON16" action="pitch_range '6,10,16,100' +1" />
<map value="0-BUTTON16" action="pitch_range '6,10,16,100' +1" />
<map value="1-JOG29" action="nothing" />
<map value="0-JOG29" action="nothing" />
<map value="1-ENCODER29" action="nothing" />
<map value="0-ENCODER29" action="nothing" />
</mapper>
Google traduction:
Hello everyone.
XDJ Custom mapping:
</mapper>
geposted Sat 07 May 16 @ 4:57 pm
As a VJ and using VDJ 8, your skin is as basic and simple to use as there is. Is there a way for the skin to remember it's size and options from use to use? Right now, it seems to default to the original install screen.
Is there a planned update/upgrade (not that it needs one)?
geposted Mon 06 Jun 16 @ 1:48 am
