Forum: Addons
Topic: Virtually Pioneer - Page: 1
geposted Wed 24 Jun 15 @ 6:22 pm
Rob is there a 4 decks in the works for the future i love your skin looks or possible one with a small window for songs list without having to choose between browser or decks view..
Steve
browser window. (1920x1080) to big !!! do you have smaller????
The browser window is resizeable, just drag the black edges...
You know what ... Thanks a loy for your work :)- really enjoying your skin ! good work buddy ! keep going on
Dj ( ,)u@rTZ
My pleasure, glad you like it.. more improvements on the way.... stay tuned :-)
hi rob? virtually pioneer plays very good...
Yeah just wanted to say thanks for the work! I wanted the RX to get used to the rekordbox feature but also wanted to keep vdj for the content unlimited library I have. much appreciated
i don't own an XDJ-RX as yet, rather the DDJ-SR, but seeing as I still use CDJ1000mk3's I am looking at a 4 channel version of this coming out, hopefully with DVS for timecode for the Mk3's!.. holding fire on any new purchases right now, as I want to see what Pioneer does with Rekordbox..
on a side note - I saw this on ellaskins youtube page (jonathan lewis) a few weeks back.. took me a while to find it as the skin isn't called " XDJ-RX " rather virtually pioneer ;) . great work though Rob, and keep it up!
Hey there... how to apply this add on?
Oh i got it
Do I need to download any other drivers/settings to go with this skin for my Pioneer DDJ-RX for VDJ8?
hi I really like you skin you have created but my problem is if I download it the skin does want to work on my pc please help
This was is great I'm looking forward for more free things from you bud!
how to install this pionner
hi dose the virtual dj 8 work with the xdj rx anyone
is this compatible to Pioneer XDJ-R1? thanks in advance
Bonjour à tous.
Souhaite acheter virtual DJ 8 pour piloter un pioneer XDJ-RX FirmWare 2.10 en utilisant la skin XDJ-RX RobGmixes (ou DJ Zaik Flow)
Quelle version VDJ Pro je dois acheter ? Est ce que le mapping est fourni avec la XDJ-RX RobGmixes (ou DJ Zaik Flow).
J'ai lu que les LEDS sur le contrôleur ne peuvent pas se piloter.
J'ai commencé un mapping sur VDJ8 DEMO le voici si quelqu’un peut me le corriger ou le compléter ou me donner un exemple pour les LEDS.
Google traduction:
Hello everyone.
Wants to buy virtual DJ 8 to drive a pioneer XDJ -RX 2.10 FirmWare using skin -RX XDJ RobGmixes (or DJ Zaik Flow)
Which version VDJ Pro I have to buy ? Is the mapping is provided with the RX - XDJ RobGmixes (or DJ Zaik Flow).
I read that the LEDs on the controller can not control .
I started a mapping VDJ8 on the DEMO here if someone can correct me or complete them or give me an example for LEDs .
XDJ Custom mapping:
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="SIMPLE_MIDI_2276_420" version="800" date="2016-05-07">
<map value="ONINIT" action="deck 1 vinyl_mode 1 &amp; deck 2 vinyl_mode 1 &amp; deck 3 vinyl_mode 1 &amp; deck 4 vinyl_mode 1" />
<map value="0-BUTTON51" action="browser_enter" />
<map value="0-ENCODER79" action="browser_scroll" />
<map value="0-BUTTON0" action="play_pause" />
<map value="1-BUTTON0" action="play_pause" />
<map value="0-BUTTON1" action="cue_button " />
<map value="1-BUTTON1" action="cue_button" />
<map value="0-SLIDER29" action="pitch" />
<map value="1-SLIDER29" action="pitch" />
<map value="0-BUTTON31" action="sync" />
<map value="1-BUTTON31" action="sync" />
<map value="0-BUTTON30" action="select left" />
<map value="1-BUTTON30" action="select left" />
<map value="0-BUTTON81" action="deck active select" />
<map value="1-BUTTON24" action="hot_cue 1" />
<map value="1-BUTTON25" action="hot_cue 2" />
<map value="1-BUTTON26" action="hot_cue 3" />
<map value="1-BUTTON27" action="hot_cue 4" />
<map value="0-BUTTON24" action="hot_cue 1" />
<map value="0-BUTTON25" action="hot_cue 2" />
<map value="0-BUTTON26" action="hot_cue 3" />
<map value="0-BUTTON27" action="hot_cue 4" />
<map value="0-SLIDER48" action="speedwheel" />
<map value="1-SLIDER16" action="jogwheel" />
<map value="1-ENCODER16" action="nothing" />
<map value="0-ENCODER16" action="scratch" />
<map value="0-JOG16" action="jogwheel" />
<map value="0-BUTTON33" action="reverse" />
<map value="1-BUTTON33" action="reverse" />
<map value="0-SLIDER30" action="startupspeed &amp; brakespeed" />
<map value="1-SLIDER30" action="startupspeed &amp; brakespeed" />
<map value="4-SLIDER11" action="crossfader" />
<map value="4-SLIDER95" action="crossfader_curve &apos;disabled&apos;" />
<map value="4-JOG95" action="crossfader_curve " />
<map value="4-SLIDER18" action="level" />
<map value="4-JOG18" action="get_level_right" />
<map value="4-SLIDER17" action="LEVEL" />
<map value="4-ENCODER11" action="crossfader" />
<map value="4-ENCODER18" action="level" />
<map value="4-ENCODER17" action="level" />
<map value="0-SLIDER16" action="scratch" />
<map value="0-BUTTON32" action="nothing" />
<map value="1-JOG16" action="jogwheel" />
<map value="1-SLIDER48" action="jogwheel" />
<map value="1-JOG48" action="jogwheel" />
<map value="1-BUTTON32" action="nothing" />
<map value="1-ENCODER48" action="nothing" />
<map value="0-BUTTON5" action="track_back" />
<map value="0-BUTTON4" action="track_forward" />
<map value="0-BUTTON3" action="seek -4" />
<map value="0-BUTTON2" action="seek +4" />
<map value="1-BUTTON3" action="seek -4" />
<map value="1-BUTTON2" action="seek +4" />
<map value="4-JOG11" action="nothing" />
<map value="4-JOG17" action="get_level_left" />
<map value="0-BUTTON17" action="master_tempo" />
<map value="1-BUTTON17" action="master_tempo" />
<map value="1-BUTTON6" action="pioneer_loop_in" />
<map value="1-BUTTON7" action="pioneer_loop_out" />
<map value="0-BUTTON6" action="pioneer_loop_in" />
<map value="0-BUTTON7" action="pioneer_loop_out" />
<map value="0-BUTTON8" action="reloop_exit" />
<map value="1-BUTTON8" action="reloop_exit" />
<map value="0-BUTTON44" action="slip_mode" />
<map value="1-BUTTON44" action="slip_mode" />
<map value="4-JOG1" action="nothing" />
<map value="4-SLIDER1" action="gain" />
<map value="4-ENCODER1" action="gain" />
<map value="4-JOG6" action="nothing" />
<map value="4-SLIDER6" action="gain" />
<map value="4-ENCODER6" action="gain" />
<map value="4-JOG2" action="nothing" />
<map value="4-ENCODER2" action="eq_high" />
<map value="4-SLIDER2" action="eq_high" />
<map value="4-JOG3" action="nothing" />
<map value="4-ENCODER3" action="eq_mid" />
<map value="4-SLIDER3" action="eq_mid" />
<map value="4-JOG4" action="nothing" />
<map value="4-SLIDER4" action="eq_low" />
<map value="4-ENCODER4" action="eq_low" />
<map value="4-JOG7" action="nothing" />
<map value="4-SLIDER7" action="eq_high" />
<map value="4-ENCODER7" action="eq_high" />
<map value="4-JOG8" action="nothing" />
<map value="4-SLIDER8" action="eq_mid" />
<map value="4-ENCODER8" action="eq_mid" />
<map value="4-JOG9" action="nothing" />
<map value="4-SLIDER9" action="eq_low" />
<map value="4-ENCODER9" action="eq_low" />
<map value="0-BUTTON35" action="set &apos;padmode&apos; 1" />
<map value="0-BUTTON34" action="set &apos;padmode&apos; 0" />
<map value="0-BUTTON85" action="loop 1" />
<map value="0-BUTTON86" action="loop 2" />
<map value="0-BUTTON87" action="loop 4" />
<map value="0-BUTTON88" action="loop 8" />
<map value="0-BUTTON36" action="set &apos;padmode&apos; 2" />
<map value="0-BUTTON89" action="slicer 1" />
<map value="0-BUTTON90" action="slicer 3" />
<map value="0-BUTTON91" action="slicer 5" />
<map value="0-BUTTON92" action="slicer 7" />
<map value="1-BUTTON34" action="set &apos;padmode&apos; 0" />
<map value="1-BUTTON35" action="set &apos;padmode&apos; 1" />
<map value="1-BUTTON85" action="loop 1" />
<map value="1-BUTTON86" action="loop 2" />
<map value="1-BUTTON87" action="loop 4" />
<map value="1-BUTTON88" action="loop 8" />
<map value="1-BUTTON36" action="set &apos;padmode&apos; 2" />
<map value="1-BUTTON89" action="slicer 1" />
<map value="1-BUTTON90" action="slicer 3" />
<map value="1-BUTTON91" action="slicer 5" />
<map value="1-BUTTON92" action="slicer 7" />
<map value="4-JOG24" action="nothing" />
<map value="4-SLIDER24" action="master_volume" />
<map value="4-ENCODER24" action="master_volume" />
<map value="4-JOG25" action="nothing" />
<map value="4-SLIDER25" action="booth_volume" />
<map value="4-ENCODER25" action="booth_volume" />
<map value="1-BUTTON18" action="vinyl_mode" />
<map value="0-BUTTON18" action="vinyl_mode" />
<map value="4-JOG78" action="nothing" />
<map value="4-SLIDER78" action="crossfader_hamster" />
<map value="4-ENCODER78" action="auto_crossfade" />
<map value="1-BUTTON81" action="deck active select" />
<map value="1-BUTTON16" action="pitch_range &apos;6,10,16,100&apos; +1" />
<map value="0-BUTTON16" action="pitch_range &apos;6,10,16,100&apos; +1" />
<map value="1-JOG29" action="nothing" />
<map value="0-JOG29" action="nothing" />
<map value="1-ENCODER29" action="nothing" />
<map value="0-ENCODER29" action="nothing" />
</mapper>
As a VJ and using VDJ 8, your skin is as basic and simple to use as there is. Is there a way for the skin to remember it's size and options from use to use? Right now, it seems to default to the original install screen.
Is there a planned update/upgrade (not that it needs one)?
50%
