I am using VMS4.1 controller. How does this controller handle auto gain from VDJ. I understand that the mixer is analog and that gain, eq's etc are handled by the controller and not VDJ. So does this mean that auto gain is not effective? Many thanks
geposted Fri 26 Jun 15 @ 8:07 am
AutoGain does affect the Gain of course. VirtualDJ will bring the loaded files to the "zeroBD" value.
the only thing that will not work is the "Remember" part of the setting, as the applied Gain from the unit is hardware.
geposted Fri 26 Jun 15 @ 6:21 pm
YO TENGO UN VMS 2 Y NO SE POR QUE LA GANANCIA EN VDJ 7 ES MUY BAJA NI EN AUTO SE PONEN PAREJA SIN ENBARGO EN VDJ8 ES PERFECTA PERO QUIERO USAR EL 7 Y ES TODO UN ENBOLE EL TEMA GANANCIAS
geposted Mon 13 Jul 15 @ 5:48 am
Hello,
please ask your question again in English or use the spanish forum.
https://virtualdj.com/forums/12/Spanish_Forum.html
geposted Mon 13 Jul 15 @ 6:36 am
