Topic: upgrade issues
I just upgraded from a "per-controller license" to a "PRO INFINITY license" and now my NS7 isn't responding properly (Specifically the right plater, right LED, and right pause/play button). The left side seems to be working fine. Thinking maybe my NS7's right channel was bad, I connected a different controler, Mix Deck, and the same thing happened. Can you help me with this problem?
geposted Fri 26 Jun 15 @ 4:55 pm
