Occasionally the skin stops being drawn properly and bits of it disappear, the browser also disappears.. vdj continues playing but it appears like the skin locks out.
Where would i start to fault find this??
Im certain there is no crashguard report (i never see any popups in relation to crashguard so i dont think that works either)
as a workaround, is there a way of creating a keyboard short-cut to invoke a screen refresh?
In the past when this happens ive managed to minimise and restore the vdj window but the skin comes back in its crashed state :(
geposted Sat 27 Jun 15 @ 8:46 pm
Are you using the default skin?
geposted Sun 28 Jun 15 @ 1:16 am
Try keyboard shortcut
load_skin
geposted Sun 28 Jun 15 @ 3:09 am
Its the focus skin, but its happened using "internal" skin too.
And thanks Dan, I'll try that too 😊
geposted Sun 28 Jun 15 @ 3:49 am
What are your system details (OS, graphics)? Things like this usually happen because of a graphics problem with the computer.
geposted Sun 28 Jun 15 @ 5:32 am
I have the same problem, but whole skin disappears - just big gray rectangle instead of VDJ8 and the music keeps playing.
Windows 7 64bit, Intel HD Graphics 4600, Intel Core i7-4700MQ, latest drivers.
geposted Sun 16 Aug 15 @ 8:16 pm
On-cpu intel graphics arent working too well for me since updating to win10
I have dual graphics and the nvidia chip has updated already but intel are behind..
geposted Sun 16 Aug 15 @ 8:29 pm
