Forum: Old versions
Topic: Compatibility with MacBook
I know that virtual DJ works with the MacBook air and the MacBook Pro, but I wanted to see if anyone had any experience with the new MacBook? Is this compatible as well?
geposted Sun 28 Jun 15 @ 4:19 pm
Yes, it works just fine, however none of the controllers use the new USB-C connector. On my test device, I bought one of these:
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=1128930&gclid=COW9geeatcYCFYckgQodklINIg&is=REG&m=Y&Q=&A=details
And then plugged a regular USB 3.0 hub into that which then gave me 4 more 'standard' USB ports. Plugged a controller in, and my external HDD, and it works perfectly.
It's a mess due to the amount of cables, etc., but it's possible and it does indeed work.
